2010 Camaro SS open air intake problem
Old May 1, 2020 | 05:43 PM
Jcook84's Avatar
Default 2010 Camaro SS open air intake problem
I recently put an open air intake on my SS. Traction control lights and engine light come on now. After a couple minutes of driving traction control lights turn off but engine light stays on. After driving a little better for a couple minutes the engine light flashes and the other traction control lights come back on and the process starts all over. Any ideas?
Old May 1, 2020 | 06:38 PM
The traction light goes on most likely by default due to the check engine light going on. Sounds like you left a sensor unplugged, perhaps one that was connected to the old intake.
Old May 1, 2020 | 07:55 PM
Jcook84's Avatar
The mass air flow sensor is reattached, however there is another line that plugged into the old air box, would there be a sensor in there also? Install has it being replaced with a supplied rubber hose but it is too short so I connected them together instead
Leeet
LS Series Tech
15
Oct 16, 2010 03:59 PM
chewybacca11
Jan 1, 2010 06:11 PM
DrRuckus13
May 14, 2008 11:32 AM
ls1c5guy
Oct 15, 2007 09:30 PM
KoRN_Munky
May 31, 2006 01:30 PM
