'89 RS w/2.8 cold idle problem
Old Apr 23, 2005 | 01:02 AM
HotRod53's Avatar
Default '89 RS w/2.8 cold idle problem
Car starts but doesn't want to keep running, you have to feather the gas pedal. Until it warms up, it doesn't want to take gas. I have an EGR code, but I have checked the diaphram and removed it and cleaned it. I have a feeling that it is something else, but still throwing an EGR code. Once the car warms up, it's fine. I also remopved and cleaned the idle mixture motor.
Old Apr 25, 2005 | 08:18 PM
erik\\\\'s Avatar
Default RE: '89 RS w/2.8 cold idle problem
EGR seliniod? i their 20 dollar or so?
hows the vac line?
Old Apr 25, 2005 | 10:42 PM
HotRod53's Avatar
Does the EGR open on first cold idle? I noticed that it is not open, and if I pull the diaphram up it idles worse. I took the EGR out and cleaned it real good too.
Old Apr 26, 2005 | 05:38 PM
erik\\\\'s Avatar
sorry, i may be totaly off with the EGR selenoid, the reason i metion is that you still have code
When was your last tune up?
also post your ?*
Old Apr 29, 2005 | 09:43 AM
DarkBirdZ28's Avatar
carburated on fuel injection.
Old Apr 29, 2005 | 09:46 AM
brain fart sry.... it could be your EGR stuck open or could be Vac lines. when you do get it to idel does it idel rough or is it smooth? if it is rough then you probly have a vac line leak. you could also have a combination.
ChevyManCam
Jan 1, 2011 11:55 AM
Za33cK
May 15, 2009 01:54 PM
shakespearesdad
Dec 1, 2008 06:09 PM
nitrojunkie
Jan 28, 2008 08:56 PM
jeez
Nov 22, 2005 06:37 PM
