3rd Gen Camaro help!
Old Sep 4, 2010 | 02:05 AM
brundieck's Avatar
Default 3rd Gen Camaro help!
Hey, my name is Matt, I just joined these forums. I currently reside in Hawaii, and I have been working on a 1992 Camaro Z28 with a LT1 engine swap in it for the past 3 1/2 months. I recently just got everything legalized in the state with the safety and registration. However after driving it for a little bit going slightly uphill on one of the highways my engine started giving out like it wasn't getting any fuel at all, the weird part is that if I pumped the gas pedal then it would provide a little gas to get it going but not very fast. I'm wondering what could have cause this and what I can do to fix it?
Also, my engine has a high knocking sound in it. A couple friends have suggested that it may be the lifters, I'm wondering if this could be the problem or if it is something else. Also if it is the lifters, will hydraulic lifters work for the LT1?
Btw, I'm new to fixing cars and all, I've been gradually learning here and there for the past 3 1/2 months since I have gotten this camaro. Please any insight will help out a lot.
Old Sep 8, 2010 | 10:14 AM
Caveman305's Avatar
does it drive ok when your not going uphill? could be many things, try checking or have your Fuel pressure checked
it could be your pump is not strong enough, a blocked fuel filter, or someone that did the swap could have left the old computer hooked up(not likely, but could happen) and that will cause havoc because its not tuned for the LT1
as for the knocking, is it a knock or a ping?(there is a difference) you would pretty much have to visually inspect that,and you are using the proper grade of fuel correct?
Old Sep 9, 2010 | 02:57 PM
brundieck's Avatar
It has a new computer the old one is gone, we changed the fuel filter and put fuel injector cleaner in it, it seems to have helped a little bit. And it is a ticking sound, I think the valves just need to be adjusted.
I can't find the specs though to adjust the valves though.
Old Sep 11, 2010 | 10:58 PM
Caveman305's Avatar
let me ask you this, does it have headers? and is the ticking coming from te pass side rear of the engine? alot of LT1's header bolts will back out(my friends fell out) on the back pass side, makes a ticking sound when the bolt is loose
not saying that you shouldnt check your motor, but i would check any loose bolts if you do have headers
Old Sep 12, 2010 | 12:54 AM
brundieck's Avatar
yes it does have headers, its coming from the driver's side though, can't tell if its coming from the rear or what. That is something we will try to look at.
