Pacesetter Headers, camaro now slower?
huh? so i got my Pacesetter headers on finally, and working. but i noticed that ive gotten a lot LESS power, now the rest of my exhaust is pretty much stock, so should i replace the rest of the exhaust and finish it? or should i focus some intake modification?
other than that should i do anything else? that might be causing my low performance?
If the install is correct there should no reason to lose power. If you exhaust is restricting the flow the headers may not add much but they should not take away anything. Did you get everything back together right? New O2 sensors?
make sure the wire for the knock sensor is on correct and is not damaged. unplug it and check then when you plug it back in make sure its in all the way. double tripple check to make sure the plug wires are in the right place. are you sure you didnt break or crack one of the plugs while installing headers.
well mostly my uncle who did most of the stuff installed the headers, i helped take them off. probably a loosened O2 sensor...but i didnt get a check engine light from it. but also i didnt get new O2 sensors, i used the old ones, they seemed fine before the headers, possibly somethings loose or maybe my EGR is still leaking in some areas.
Im pretty sure you know this Gorn from a previous thread, i did use a sealant to stop the leak. if the EGR leaks, could that be a cause for my loss of power?
I do not think a exhaust leak that small could cause a noticable change in HP. If you had a vacuum leak at the EGR vavle that could and would cause a drop in power.
I don't know if it true but I have been told that the stuff the factory puts on the header to keep them from rusting can damage an O2 sensor or in your case push an older one over the edge. I have been told by a couple of guys I respect to install the old O2 sensors in new headers until the car has had one test drive then swap in the new sensors.
Interesting tip, thanks! The stuff you mentioned is just oil or grease -- but I could see this might be possible...
Perhaps ya should have went for FFF's Long Tube Headers for potentially more power in lower RPMs -- If that's where you are feeling power missing...
As bad as those stock manifolds are I would surpised if a dyno showed any downside no less enough for a driver to feel it. I would agree with you if it was an 02. He's got something else going on.
