Fuel pump getting no power
Old Aug 3, 2010 | 11:58 AM
jesse2k18's Avatar
Default Fuel pump getting no power
I need some help here, I've done a lot of reading on the forums about fuel pumps and changing them out. So, my fuel pump went bad (I thought). I changed it out using the trap door method and the new fuel pump would not work. I jumped the new fuel pump to the battery using the fuel pump prime connector and the fuel pump did prime after this. So after this I tested the wire at the relay , I' think I'm supposed to get a hot reading from the orange wire which is from the battery, and a hot reading from the green wire which is PCM with the key turned. I'm not getting a hot reading from either of these. What could be the problem? I changed out all the fuses and still nothing? anyone have this problem and if so how did you fix it?
edit* I also changed the relay to a new relay to make sure it wasn't the relay that was not working. The new relay had no effect.
Old Aug 3, 2010 | 03:20 PM
what yr and model car we talking about?
Old Aug 3, 2010 | 08:31 PM
jesse2k18's Avatar
Oh geez sorry, I guess I overlooked that, it's a 97 Camaro with 3.8L v6 engine.
Old Aug 3, 2010 | 08:37 PM
well im sorta of no use to you. lol 97 is way different than i have. i know the body control modual controls alot more in the 97 and may very well control the fuel pump. there are some good wiring diagrams on shbox. heres a link to the repair home page. good stuff.
http://shbox.com/1/4th_gen_tech1.html
Old Aug 4, 2010 | 12:58 AM
jesse2k18's Avatar
Hopefully this will help out a bit. I'm going mad with this thing. I've got it all torn apart on the inside and I have the Haynes manual with the wiring diagram but it's not easy to read and I can't find anything on the internet. It told me to change the fuel pump fuse in there and that the fuse was in the i/p panel #3 fuse. It says it was a 15 amp fuse. I couldn't really tell which one it was so I replaced every single 15 fuse in the car, still no help.
From what I can gather around on these forums I'm leaning toward it being a faulty PCM. I hope it's not because I don't really know what it will take to replace that let alone where to find one and get it programed for the car.
Old Aug 25, 2010 | 04:55 PM
lswhaaat's Avatar
does it have a fuel shut off safety switch?
Old Aug 25, 2010 | 05:40 PM
^ No, but Fords have that feature.
Old Aug 25, 2010 | 06:47 PM
This may help.
How it works.
When key is turned on the PCM will operate the fuel pump relay. The fuel pump relay provides battery power to the fuel pump. NOTE! If the engine does not start within 2 seconds, the PCM will release the pump relay and the pump will have no power.
The pump circuit has 2 power feeds:
1) Pump Power, Always hot through the 20 AMP fuel pump fuse (under hood panel), through the closed contacts of the pump relay (under hood panel), and then to the fuel pump.
2) Relay control, 12 Volt from the PCM to the pump relay coil. The12 Volt power to relay coil is provided when the ignition switch is in the ON or Start position, but only for 2 seconds if the engine fails to start.
Jacob
Jul 6, 2011 03:14 PM
anthony7888
70-81 V8 Tech
Jun 19, 2011 03:07 AM
mkdubs
Nov 25, 2007 07:55 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
