MSD Pro Billet Optispark Vs LS1 coil swap.
Old Jun 30, 2010 | 04:59 PM
pd411's Avatar
Default MSD Pro Billet Optispark Vs LS1 coil swap.
My opti is starting to go on my 94 LT1 383 stroker.. I was wondering if i should go with the MSD opti, or the LS1 coil swap?
Thanks,
Eric
Old Jun 30, 2010 | 05:08 PM
Depends on what part is going on the opti. The LS1 coil conversion still needs to use the optical part of the opti for crank triggering. So if the optics are crapped up, you'll have to open it up and clean it out. Or, if the bearings are shot and the rotor shaft is wobbling, you'll need a new opti anyway.
Old Jul 2, 2010 | 04:01 PM
efi makes a ls1 conversion, runs about 2500. bucks. takes the opti out completely and switches to a ls1 ecm. you have to have the crank sensor on the front cover though so you would need to change it.
Old Jul 2, 2010 | 07:44 PM
Grandpaswagon's Avatar
Is there an advantage to that other than getting rid of the opti? Does it produce better power?
Old Jul 3, 2010 | 01:34 AM
now that i dont know for sure. i would think there close to the same.
Old Jul 3, 2010 | 09:19 AM
Wow, that is one expensive mod for little to no gain.
chernmax
Jan 28, 2012 12:42 PM
lazybeagle
May 23, 2010 11:51 PM
Frechles71
May 3, 2007 10:56 PM
allbaugh_04
Mar 26, 2007 11:17 PM
KoRN_Munky
Dec 4, 2006 01:46 AM
