Ignition switch
Old Mar 31, 2005 | 03:03 AM
Scott's Avatar
Default Ignition switch
My son has a 1971 camaro. The ignition switch needs to be replaced and is located on the steering column. He does not know how to remove the switch does anyone know how to do this?
Old Mar 31, 2005 | 12:44 PM
Patrick's Avatar
Administrator
Default RE: Ignition switch
i think you would have to remove the plastic or metal steering column and under there you should have better access to the ignition swtich. i know that is kindof vague, and i apologize, but i unfortauntely dont have a 71 camaro [&o]
Old Mar 31, 2005 | 07:18 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
well i know the 3rd gens you need to remove the steering column, not sure on the second gens sorry
Old Mar 31, 2005 | 08:14 PM
Patrick's Avatar
Administrator
you have to remove the entire column? wow...that would be awful.
Old Apr 1, 2005 | 03:55 AM
flyin68's Avatar
If it is like many other chevy's there should be a small key hole to release the ignition switch, some require a paper clip, others something bigger like a screwdriver that releases the whole switch mechanism, consequently it makes these cars very easy to lift.
Delray Gugle
Apr 7, 2014 07:04 PM
tampatony
Feb 20, 2014 01:59 PM
evilmnky45
Jul 31, 2011 05:24 PM
qqqa
Jul 28, 2008 12:27 PM
w0211644
Mar 14, 2007 01:12 AM
