bad vibrations
Old Mar 28, 2005 | 06:41 PM
flyin68's Avatar
Default bad vibrations
I have had a fairly significant vibration in my 68 camaro ever since I have owned it. You can fill it in the shifter and steering wheel and is associated only with engine RPM, for example if I push in the clutch and let off the gas it goes away. I thought a couple of easy fixes would be to replace the fly wheel and harmonic balancer, but it is still there. I was under the hood of my car the other day and noticed that the engine block seems to be very smooth running with my hand on it but it is quite a bit more pronounced touching the shifter, even in neutral. These vibrations are worst from idle to about 3500 RPM. Does anybody know if this sounds like a bent input shaft on the Muncie? Thanks for the help.
Old Mar 29, 2005 | 12:20 PM
Patrick's Avatar
Administrator
Default RE: bad vibrations
if the engine feels very calm to the touch..perhaps a mounting issue? or a block to tranny problem?
Old Mar 29, 2005 | 06:43 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
yes sounds like a trans mount issue... i can remember bein slapped in the leg a few times in my friends TA by that damned shifter
Old Apr 1, 2005 | 03:51 AM
flyin68's Avatar
I just got done doing a frame off resto and replaced all the mounts, rebalanced the driveshaft, repaced the springs with multi's, and had the rearend reworked. I am running out of things to replace!!!
Old Apr 2, 2005 | 01:57 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
well obviously there is something wrong/ mistorqued or bent somewhere...could be anything i guess sorry
allmiller4u
Jul 17, 2013 07:58 PM
brownstone101
Jan 15, 2011 08:45 PM
CMan84
Mar 21, 2010 11:11 PM
r00tk1ll
Nov 21, 2009 10:00 AM
vega1485
Jan 12, 2008 09:23 AM
