Putting a 2000 Corvette Stereo in a 1997 Camaro
Old Jun 30, 2006 | 01:17 AM
94V8jag's Avatar
Default Putting a 2000 Corvette Stereo in a 1997 Camaro
I am trying to replace the 1997 Bose Stock stereo in my Camaro with a 2000 Bose Stock Stereo from a Corvette. I believe it is the same stereo. They look identical from the front. However, I removed the 1997 stereo and when I was going to install the Corvette stereo I noticed that one of the wire harness connections was different. The antenna and the connection on the left are a match. The new Corvette stereo has an additional four pins right below the nine pins on the other connection. Do I need some sort of an adapter or can I just plug everything in and not worry about those extra four pins? Please help me.
Old Jul 1, 2006 | 05:02 PM
02renegade's Avatar
Default RE: Putting a 2000 Corvette Stereo in a 1997 Camaro
plug it in and go, generally those 4 pins are for vehicles that had steering wheel controls. If you buy an aftermarket harness to replace the stock head unit you never use those 4 wires.
Old Apr 22, 2008 | 09:59 PM
Skippysnax's Avatar
ya man u should be fine. but id be careful cause bose does some weird ****.
DarkKnight
VS
28
Oct 13, 2010 08:53 AM
blackenedss
Jan 28, 2010 11:14 AM
siueparent
Sep 29, 2009 07:54 PM
Mx35foxracing
VS
19
Dec 3, 2007 10:19 PM
hasenbonkers
VS
10
Jun 22, 2006 09:45 PM
