Tachometer redlines while at idle?
Old Mar 21, 2005 | 05:15 PM
rodsbycod's Avatar
Default Tachometer redlines while at idle?
I'm new here and seems like a cool forum so far, my tach isnt working right and after I start it up it goes to redline, any suggestions? This is on a 91 camaro RS 305 with automatic trans.
Old Mar 21, 2005 | 06:13 PM
Patrick's Avatar
Administrator
Default RE: Tachometer redlines while at idle?
how new is the tach? is it the stock unit?
Old Mar 21, 2005 | 07:02 PM
rodsbycod's Avatar
Its the factory unit, I believe it has never been replaced.
Old Mar 21, 2005 | 08:57 PM
Patrick's Avatar
Administrator
im guessing that the tach is part of the factory gauge cluster in the dash? i am not sure if you can replace it, or if you have to replace the entire gauge cluster...it has to be soemthing with the tach itself...because i believe it is run off of the distributor, but i am not sure..my camaro had an aftermarket tach, run directly to the dist. i am not sure where, but i would suggest trying to find out where the wire is (on the dist or into the ECU) and see if you cant check the connection...it may just be that the tach is going bad..
Old Mar 21, 2005 | 09:30 PM
rodsbycod's Avatar
ok, thanks for the info. Just looking at it, it looks like its all 1 piece. Any other links that I should try?
cpookie123
Sep 24, 2009 10:23 AM
71CamaroZ28
Apr 24, 2009 11:12 PM
250motorsportz
Mar 31, 2008 12:57 AM
milferd3@yahoo.com
Jan 19, 2008 07:54 PM
burnout
Jan 9, 2007 06:31 PM
