2.8 back together but no fire
Old Mar 20, 2005 | 11:53 PM
HotRod53's Avatar
Default 2.8 back together but no fire
I got the intake leak all fixed up, got all of the valves adjusted, made darn sure that when #1 was on top that the rotor pointed to #1 wire, I rolled the motor over with the coil wire off to circulate the new oil to flush some contaminates, the coil arced from the post to the intake so I'm sure that I had spark (then I pulled the coil input wires). Once I changed the oil and put the coil wires on, it sounded like it coughed up through the intake maybe once. I can hear the fuel pump coming on, but does it take some time to fill the fuel rail again? Everything looks right but no fire, any suggestions from you guys who have done these 2.8s before?
Old Oct 20, 2005 | 04:38 AM
mofur's Avatar
Default RE: 2.8 back together but no fire
Hey I have an 87 2.8 L and I've an engine swap so I know that these engines can be frustrating. Well if its fuel injected you sould be able to check the fuel pressure at the fuel block asembly (located on the back of your fuel rail, and should have the presure cap on it if its like my 87) and if it has fuel presure I would think that maybe the injector wires got crossed. But not competely sure. hope I could help a little.
Old Oct 20, 2005 | 04:57 PM
Unless you changed it, the fuel pump will run for a little while, and if the engine does not start and bring up oil pressure, the fuel pump shuts down. Make sure you have the plug wires in the proper order.
Old Oct 24, 2005 | 04:36 AM
mofur's Avatar
That was my exact next thought. Its usually something stupid like that.
NEW_CAMARO_OWNER
Aug 11, 2010 05:45 PM
84ryder
Jan 19, 2010 11:03 PM
Nitemare3o5
May 6, 2008 07:55 PM
vray321
Oct 1, 2007 09:23 PM
bluovlh8er
Sep 15, 2007 10:58 PM
