Hesitation and back fire
Old Jan 19, 2010 | 08:13 PM
84ryder's Avatar
Default Hesitation and back fire
ok so i just got an 84 camaro it has a 305 in it the guy i got it from said it had a holley 650 wich turned out to be a 600 because i took it to a local perfromance shop and they took some number off the front and said its a 600 but when i get on it real hard it will hesatate or back fire or both i had a friend adjust the carb and he said it may need to be rebuilt or the timing may be off????? any advice helps
Old Jan 19, 2010 | 11:03 PM
Rebuild the carburetor, then check your timing. Maybe even give it a tune up, (plugs, wires, cap & rotor), if it looks like it hasn't been done in a while. And a 600 is plenty for a 305.
NEW_CAMARO_OWNER
Aug 11, 2010 05:45 PM
Nitemare3o5
May 6, 2008 07:55 PM
vray321
Oct 1, 2007 09:23 PM
bluovlh8er
Sep 15, 2007 10:58 PM
HotRod53
Oct 24, 2005 04:36 AM
