supercharging a Big block
Old Jun 18, 2006 | 11:15 PM
SplitBumper's Avatar
Default supercharging a Big block
anyone on here have any exp. with this i am seriously considering it for my 396?
if there is a thread about it please link me
Old Jun 20, 2006 | 05:14 PM
Default RE: supercharging a Big block
I never tried supercharging a Chevy big block, but I have done several Chrysler hemis, and I suspect the idea is the same. To make real power you need a strong bottom end, that means forged everything, low compression between 7&8:1, sodium cooled exhaust valves, big exhaust to let all the burned gases out, fuel system big enough to handle the power you expext to make. Blower grind cam. Good flowing heads. Most important high boost (around 20 PSI +). Strong ignition to light up the big charge. Avoid blow through systems, too fussy to have fun. For street use I suggest something that looks impressive such as an 871 with twin 4bbl on top. For racing, go with a screw type supercharger, topped with fuel injection.
Old Jul 29, 2006 | 07:02 PM
Blade's Avatar
June 2007 ROTM
Well are u gonna be running all the "good stuff" in the motor. High comp pistons all that good stuff and running cam2 bc if ur not then its all gonna be for looks bc then the highest piston u can run in 9 to 1 and run on pump gas and if would be a stock motor.
SS/Z28cam
Feb 26, 2010 11:45 PM
jamguitarist91
15
Jul 27, 2008 03:45 PM
corruptkid29
Sep 3, 2007 08:59 PM
redthunder99
Aug 21, 2006 09:15 PM
