keep blowing fuses
so with all new fuses i have no heat/ac but everything else works. when i put the cigarette lighter iin its hole at some random point it blows all but 1 or 2 fuses, the seller later told me "oh ya dont plug that in i think it shorts out the car" he also said it has an electrical problem and thats why the heater/ac doesnt work
so id like to know how do i start finding problems? would a voltmeter show me the way?
also there is a weird hum coming from the hatch motor nits a constant hum as soon as the ignition is on.
what yr and model we talkin about. yes a volt meter and a test light will be very helpful. check your relays. follow the lighter wire and see where it goes and what u find.
Look inside the lighter socket to see if there is any crap (foil gum wrapper, etc.) to cause a short.
The hatch motor humming might mean it's not turning off? Is it with the hatch open or closed, or both?
Lighter is a very common short problem. BUT it should only blow the Lighter/ACC fuse. Not all the fuses except 2. That sounds more like a problem with a body ground or the fuse box itself. Intermittent shorts can be the worst to track down. I have had zero luck talking guys with no electronic back ground through these types of repairs.
its an 85 z28 tpi t-top. the noise stays on when its shut, i think i remember it humming with te hatch open. i will now commense the saearch...
lol thanks for the inspiration Gorn. my experience is limited to wiring lights and the scratch built air horn system for my jeep.
i know people who could take car of it easily but i dont want to keep bugging them with things i can do on my own.
