Every Time I Turn My Lights On My Stock Gauges Stop Working
Old Nov 16, 2009 | 02:29 PM
-Tommy-'s Avatar
Question Every Time I Turn My Lights On My Stock Gauges Stop Working
when i turn the lights, its like i turn the ignition off, all the gauges go to there resting area
Old Nov 16, 2009 | 06:01 PM
not real sure of the yr but sounds like a ground problem. check along the column and under the kick pad, look for ground wire screws. will have to take some molding off. while your down there look around under the dash for lose or bare wires, special attention to the plugin n wires to the headlight switch.
Old Nov 16, 2009 | 07:16 PM
microkid's Avatar
March 2011 ROTM
i had an issue with that as well, it turned out the dash bulbs were grounding through the postive side of the circuit, so it would cancel out the gauges. i fixed it, but something else went wrong so i ended up just buying an aftermarket set of gauges. but it does sound ground related. i cant pinpoint it or even make a suggestion on where to start though
Old Nov 16, 2009 | 07:41 PM
-Tommy-'s Avatar
I will take a look at that when i get time thanks
craby
Apr 30, 2015 10:31 PM
mp734
Jul 3, 2014 07:40 PM
Geawiel
May 12, 2013 05:11 PM
Dana
Sep 21, 2012 10:55 AM
350badass
Sep 5, 2007 07:56 PM
