'94 Camaro Z28 Suspension
Old Nov 13, 2009 | 05:34 PM
imalixZ28's Avatar
Default '94 Camaro Z28 Suspension
Alright kind of a newb question here, but this is the first Camaro I've owned. The suspension is real tight, I feel every bump and rock in the road. Is the stock suspension supposed to be that tight?
*EDIT* Sorry for posting in the wrong forum, didn't notice the Suspension board towards the bottom
Old Nov 13, 2009 | 06:09 PM
worn parts in the front suspension will magnify bumps. could be struts or ball joints. have a look at the stuts and see if they look really old. could also be out of alignment.
Old Nov 13, 2009 | 06:16 PM
Also check to see that your tires aren't overinflated to the point of being as hard as a rock.
Old Nov 14, 2009 | 05:21 PM
imalixZ28's Avatar
Thanks, turns out I could use new ball joints
Old Nov 14, 2009 | 05:47 PM
outer tie rod ends are common to failure also and are easy to change. if your steering is tight then i wouldnt think thats an issue. last 6 to 8 yrs for me.
Old Nov 16, 2009 | 07:40 PM
imalixZ28's Avatar
yah, no problems with the steering
Po' Boy
Oct 31, 2013 03:49 PM
shawnathan
Jun 4, 2012 09:56 AM
Cornbreadx
Feb 21, 2012 10:54 PM
mitchecw
Feb 14, 2011 11:11 AM
srich1207
Apr 9, 2008 06:28 AM
