1977 camaro Z28
Old Nov 12, 2009 | 01:13 AM
RIP70's Avatar
Default 1977 camaro Z28
hi just bought a 77 camaro z28 it has a rebuilt 350 out of a 74 camaro and new transmission and new clutch... but the gas and speedometer gauge does not work... i plan on replacing the cable but it would help if i could get a step by step on how to do both thanks....
Old Nov 12, 2009 | 04:37 AM
is the cable broken? if it is broken ull need to unhook it at both ends (one at the trans and one at the back of the speedo) and pull the cable out of the cable housing. most likely one piece from each end. measure it to make sure u get the right one from the parts store.
Old Dec 10, 2009 | 04:30 AM
kds74ltz's Avatar
also check the speedo gear in the tranny, those get brittle and break all the time....its right behind the cable when you take the cable off the trans
Legitballerx24
Jun 11, 2013 02:42 PM
supercharged
Mar 16, 2010 05:08 AM
macnjz28
70-81 V8 Tech
Jun 4, 2009 06:45 PM
MayonnaisePlant
Oct 14, 2008 04:51 PM
MayonnaisePlant
Oct 13, 2008 11:09 PM
