Intake Gasket leak
Old Nov 10, 2009 | 02:30 PM
Vandee's Avatar
Exclamation Intake Gasket leak
alright so i have a 96 3.8L v6 and i just recently found out that i have a intake leak. i can see the antifreeze run out and drip on the ground. so im gonna replace the gasket this weekend and im 18 and havent done much work on cars and my dad will be gone hunting so im gonna need some help i was just wondering if anyone had any tips for me anything i should be watching out for while im pulling stuff off the motor.
Old Nov 10, 2009 | 04:46 PM
Jonny Dubyah's Avatar
Take alot of "before" pictures so you have visual references..and take yhem as you go along..
Old Nov 10, 2009 | 09:43 PM
Get a repair manual for your car. The bolts will need to be torqued correctly and in the proper sequenced in order to avoid warping things and having the leaks return. Also get all the old gasket material completely cleaned out.
Old Nov 11, 2009 | 06:20 PM
osduck5's Avatar
Take your time. Label the wiring connections and spark plug wires with tape and mark them so that it will be easier get plugged back to the right connections and the right places on the coil packs. Be careful when removing the fuel rail, don't let fuel squirt in your eyes when you bleed it. Put it in a plastic bag to keep dirt out of your injectors. You should also get new fuel injector orings before you start to ensure you get a good seal when you re install the fuel rail. Oh, and don't let anyone turn the key on to listen to the radio when you have the fuel lines disconnected! Don't ask me how I know that!
Old Nov 15, 2009 | 06:50 PM
Vandee's Avatar
ok im stuck i got everything off almost im trying to pull the intake off but its stuck on by the tiny little "thing" i'd call it a bolt but idk what it is or how to remove it! it is on the drivers side of the intake at the front of the motor.
Old Nov 15, 2009 | 10:13 PM
osduck5's Avatar
Ok, a couple questions first.
1. Are you talking about the upper intake or the lower intake?
2. If it is the upper intake, did you remove the thermostat housing. It has a long bolt that holds the upper intake down.
My guess is that you are trying to remove the lower intake and the L shaped plastic water pipe on the front is holding it down. You may have to remove the bracket that the heater hoses are attached to to slide that piece out.
A pic of what is holding it down would help.
Old Nov 15, 2009 | 10:32 PM
Vandee's Avatar
Alright ill get a pic or 2 up tomorrow i really dont know exactly what im taking off. my dad told be to start pulling the intake off i told him idk what im doing he said just pull stuff off take alot of pics all we will get it back together so i did just that
Old Nov 16, 2009 | 10:11 PM
osduck5's Avatar
First off, the intake is divided into 2 parts, the upper intake which is the top part that has 3800 molded into the metal. The second part is the lower intake which has 6 big holes in it and is what is sitting directly under the upper intake. Inside the lower intake, you will find, I believe, 4 more bolts that have to be removed that are down in teh openings, 2 at the front and 2 at the rear. After those bolts are removed, the only other thing holding it would be a black plastic L shaped tube in the front that is a water tube. It should lift right off if you have all the bolts removed. Double check to ensure you have all the bolts removed. I have a thread that is a couple weeks old with some pics. I will see if I can find it and post a link to it.
Old Nov 16, 2009 | 10:17 PM
osduck5's Avatar
Old Nov 19, 2009 | 06:56 PM
Vandee's Avatar
wow thank you i was stuck on the long bolt in the thermostat housing. i thought maybe the pin that helps line it up was what i was stuck on. I now realize that it was just a pin . i also have the lower intake off. and i have a couple questions. first i noticed that one of the six hole on the intake looks clean just discolored and the rest are black and dirty? is the common? also when reinstalling the lower intake how do you get that L shaped water pipe back on? i was told that you have to set the Intake with the new gasket down straight so you don't mess up the alignment of it.
Edit: ok never mind about the intake holes color thing i just looked at ur pics and they are the same way so im assuming that it is not a problem
