How do u replace a 86 camaro 2.8 transmission?
Old Nov 6, 2009 | 05:55 PM
Trippin15's Avatar
Default How do u replace a 86 camaro 2.8 transmission?
Old Nov 6, 2009 | 07:38 PM
pick up a dealer service manual for your yr and model. heres one thats been well used but only 25 bucks. should be able to find a better one for 50 to 90.
http://phoenix.craigslist.org/nph/pts/1435433628.html
Old Nov 6, 2009 | 09:14 PM
Its pretty simple,
First you take the old one out.
Then you put the new one up in place
Bada Bing Bada Boom, Its replaces.
A lot of guys forget the "Bing" part and end up replacing the new tranny is less then a year so be sure to follow the instuctions to the letter.
Old Nov 7, 2009 | 09:31 PM
mighty mike's Avatar
^^^lol. ur a dork.
ok remove the driveshaft, crossmember, tranny lines, bolts from torque converter, than the tranny bolts. then reverse for installion.
Old Nov 8, 2009 | 08:28 AM
Very carefully.
Old Nov 8, 2009 | 08:48 AM
Originally Posted by mighty mike
^^^lol. ur a dork.
You forgot the Bing,, The bing is flushing out the tranny cooling system. Since the current tranny failed there is most likely metal in the cooling system. You also left out how to deal with the torque converter and how to make sure its in all the way. I have replace half a dozen front pumps in trannys from clueless do it yourselfers. That was the ones that figured out they screwed up. If they had try to start the car then the whole tranny would need pulled apart. For someone asking for step by step instuction for what is a simple task they really need a manual or help from someone who has done it before and the tools to do it. That is why I was being a "dork" BTW your instruction are just as big a joke as mine, No mention of the shifter the speedo cable the dip stick the Modulator/TV cable or the torque arm.
Old Nov 9, 2009 | 09:44 PM
my instructions werent meant to be specfic bolt by bolt instructions. it was just to point him in the right direction.
edit: now that i thought bout it u meant follow the directions from the manual, huh?
Chaotic94
Mar 6, 2011 09:23 PM
camaroman18
Jun 11, 2010 04:25 PM
camaroman18
Jun 7, 2010 09:24 PM
Wyo77camaro
Nov 21, 2009 03:22 PM
VanHalen
Feb 9, 2009 02:39 PM
