cleaning gum varnish in gas tank
Old Jun 9, 2006 | 07:08 AM
sewerrat's Avatar
Default cleaning gum varnish in gas tank
I'm working on a 88 camaro v6 MPFI with severe varnish in the tank. The car has sat for 3 years and does not run. The previous owner replace the pump once before which failed shortly. I need your input to clean out this severe amount of hard gum and varnish formed in the tank and fuel inlet lines. I'm trying to prevent buying a new tank. If anyone has had this problem, what did you use to clean it? I'm trying to avoid buying a new tank, sending unit cradle and fuel lines. I am replacing the fuel pump again though. I've gotten suggestions from local mechanics like soaking everything with diesel with glass marbles and shaking the heck out of it, to pressure washing. Please give your input. Thanks
Old Jun 15, 2006 | 05:25 PM
mattvogt's Avatar
Default RE: cleaning gum varnish in gas tank
How much is a new tank? A new tank should be about as much as a tank of diesil fuel. JK...
Old Feb 1, 2007 | 05:34 AM
illumastar's Avatar
did you try seafoam it orks wonders at breaking crap up
Old Feb 1, 2007 | 01:23 PM
Get a new tank, that gunk and rust will keep coming back and mess up your fuel system.
Old Feb 18, 2007 | 03:21 AM
vanilla sky's Avatar
i'm with pete. buy a new tank. if a new tank weren't available, then i'd consider chemically cleaning and sealing the existing tank.
at advance auto, they're $200 without the filler neck, and $230 with the filler neck. with a car this old, i think i'd opt for the one with the filler neck.
Old Feb 24, 2007 | 04:56 AM
sewerrat's Avatar
Yep, you guys were right. The tank just kept on rusting on the inside.Back in Nov. 06 I finally broke down and bought a new tankalong withanother fuel pump and strainer. Since then I haven'thad a problem. Thanks again.
Sicilian
Apr 24, 2013 07:02 PM
87Chev
Mar 4, 2010 07:10 PM
cplthomas
Apr 1, 2008 10:35 AM
350rs
Mar 5, 2007 12:38 PM
bill12690
Feb 5, 2007 01:27 PM
