carb gulp valve
Old Oct 31, 2009 | 04:52 PM
blue max's Avatar
Red face carb gulp valve
i have a holley model 6210 quadrajet type carb and it has a plug called the gulp valve. right now it is plugged. can i used this as a vacuum source for my power brake hose.
Old Oct 31, 2009 | 05:43 PM
As long as it has an opening that's been drilled all the way through the base of the carb, then yes you can. Are there threads there for you to screw a nipple into, or are you going to need to thread it? Don't you have a vacuum fitting at the rear of the intake manifold?
Old Nov 1, 2009 | 06:08 AM
blue max's Avatar
the carb has a fitting that fits a 5/8 hose. i can remove the plug with a screw driver. the reason i need to use this fitting is because the carb is a double pump and the secondary mech pump lies over any fitting i install on the intake manifold. it is that close. the opening of the fitting extend out to the opening of the intake manifold. so i guess it gets full manifold vacuum and not any gas/air mixture.
albo1989
Jul 1, 2010 07:40 PM
blue max
Dec 19, 2009 08:33 AM
79camaro505
Feb 22, 2008 08:02 PM
GMDCAMARO
Feb 1, 2008 08:06 PM
