fuel pump
Old Oct 28, 2009 | 08:16 PM
letsride212003's Avatar
Default fuel pump
i have an 85 camaro v8 everything is stock working on replacing the fuel pump its not in the gas tank under the engine rather and im stuck the new pump i bought came with directions and it says that the push rod needs to be in a certain spot but will not move when i try to move it what did i break?
i have the book but it just brings me to thousands of different pages on what to do hoping any of you can help me in finishing the job
Old Oct 28, 2009 | 09:03 PM
I doubt if you broke anything, it would take a sledgehammer to break the push rod. Is the rod slid up inside the block a little, enough to slide the arm of the pump under? It may have slid down and now resting on the mounting plate? Then you'll need to grab it with a long nose pliers and slide it up at an angle. I usually just hold it up with my finger and quickly remove the finger and slide the arm under the rod at the same time before it slides back down. Another way is to remove the bolt that is in the front of the block just adjacent to the pump opening. You get a longer bolt, hold the rod up, and turn the bolt in just snug enough against the rod to hold it. Get the pump in, remove long bolt and reinstall short one. And don't forget the gasket first.
jon_uscg2001
Aug 25, 2011 12:23 AM
nehidustin
Jun 28, 2010 07:30 PM
carmodder
Jun 23, 2008 12:50 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
