rear end issues
Old Oct 27, 2009 | 07:30 PM
thepannys's Avatar
Default rear end issues
I have a 69 Z28 that i have been rebuilding, for some reason when i bought it came with a 10 bolt rear end. I located a 12 bolt posi unit with the correct date code that came out of a 69 camaro also. I mounted it onto my car the posi unit seams to work perfectly except on long sweeping curves on the highway it has a funny feeling like the axle is moving side to side, can anyone help me with this problem?
Old Nov 8, 2009 | 09:00 PM
Double check the mounting bolts after driving a short while. Also, does your car have a rear swaybar? Most Z28's did, but if not that might be a needed item.
Old Nov 9, 2009 | 10:50 AM
The clutches in the center section are more than likely hanging up. Change the oil and don't forget the posi additive. Although, I wonder if the (one post) OP is coming back?
PTl5spd
May 22, 2012 12:10 AM
craby
Feb 11, 2011 04:14 PM
jason7504
Nov 9, 2010 07:38 PM
Pro78z28
Jul 30, 2010 05:04 AM
mbyers841
Jul 15, 2009 08:06 PM
