EGR Issues
Old Oct 27, 2009 | 12:17 PM
pintobean11's Avatar
Default EGR Issues
I took my car to autozone yesterday to pull the codes and they told me that it was popping up with an EGR code. I want to be able to just take it off and clean it first and see if that does anything.
I searched for a possible sticky but EGR is too broad of a word. Can anyone help me out on how this can be done? Thanks!
I have a 2001 Camaro, obviously with the 3.8.
Old Oct 27, 2009 | 03:44 PM
Toneman07's Avatar
the egr valve on our car is an electronic EGR valve cleaning the inside usually doesnt work more then likely you need to replace it but if you want you can try to clean it out its located on the top front drivers side of the motor i beleive 3 bolts and the electrical clip and it pops right off i replaced mine about 3 months ago took 5 minutes i attached what u are looking for down at the bottom /// sorry its a link cant figure out how to get the damn pictures to work ....
http://www.conquestauto.com/catalog/8c_1_903_1.JPG
Old Oct 27, 2009 | 08:07 PM
Masospaghetti's Avatar
It's only two bolts and an electrical connector...super easy. Can be pricey though. Might want to try a junkyard first.
Old Oct 27, 2009 | 10:05 PM
Toneman07's Avatar
thats right i pulled of three haha but ya junkyard is where i got mine it was $5 versus new one at $100
Old Oct 27, 2009 | 10:16 PM
750chop's Avatar
sorry to threadjack, but what are the negative effects of say... disconnecting that p.o.s. and blocking off the hole on an OBDI car. 94 3.4?
Old Oct 28, 2009 | 12:03 PM
I actually went downstairs last night and realized it was right there in front. 2 minutes and that bltch was popped off. I did manage to lose one of the nuts.
Anyway, 750chop I was told by someone else to do the same thing as well. Does anyone have any input?
Old Oct 28, 2009 | 02:15 PM
Toneman07's Avatar
as long as you dont have to pass an emissions test in your state you should be fine the function of an EGR valve is to recirculate exhaust gasses to reduce NOx emissions thats all
Old Oct 28, 2009 | 02:42 PM
GMDCAMARO's Avatar
I just replaced mine. Its wasn't cheap, but not to expensive either, $70.
Old Oct 29, 2009 | 07:40 PM
mybbz28's Avatar
so if we just unbolt the egr and cover it, it should run fine? any idea dose it help in the HP ?
