94 t56 swap help
Old Oct 18, 2009 | 01:38 AM
greasemonkey2319's Avatar
Default 94 t56 swap help
i found a 96 t56 trans i want to buy and put into my 94 and wanted to know for sure if the bellhousing bolt patterns are the same before i buy it.
Old Oct 18, 2009 | 03:40 AM
95slvrZ28's Avatar
If it came out of a 96 Fbody you're not going to have any issues, the drivetrain didn't change other than the addition of 1 cat in 1996. That said, you have a reasonably sized project ahead of you, hope you did your homework...
Old Oct 18, 2009 | 02:32 PM
r6rider's Avatar
does your tranny come with the flywheel and bellhousing? if so how much did you buy it for? Thats a big project that i was thinking of doin
Old Oct 18, 2009 | 04:07 PM
It is a whole other camaro i found i want to use the interior and trans out of. I know theres alot of parts needed for the swap so i figured a whole car would be easiest. I know with gm trucks a few years had a metric bellhousing i didn't know if the camaros might of had that issue too. Thanks for all the input
3800_seriesII
Aug 14, 2012 07:24 AM
9434V6
Sep 8, 2011 11:51 AM
xXChipXx
Aug 1, 2010 10:39 PM
miclo88
Oct 15, 2009 07:38 PM
85z285.0
Jun 2, 2007 03:19 PM
