Hatch Struts Squeaking & Driving Me Nuts
Old Oct 17, 2009 | 10:32 AM
LHill00Z28's Avatar
Default Hatch Struts Squeaking & Driving Me Nuts
Hi Everyone.
The rear hatch support struts on my 2000 Camaro squeak occasionally when I drive the car & it drives me nuts. Have any of you had this irritating problem??? If so, did replacing them stop the squeaking?? Did you buy GM/OEM replacements??
Old Oct 17, 2009 | 11:00 AM
maudyZ28's Avatar
ha ha, actually i have a squeak and although it only occurs rarly , that whait it is! Its hard to tell where all the noises come from when all you can here is an exhaust. Let me know how you get on cause i might just oil the joints and stuff when im back home, see if that solves it
Old Oct 20, 2009 | 06:23 PM
LHill00Z28's Avatar
Okay so I picked up a set of OEM struts from the dealer (my old friend works there so I always get a better price than "dealer retail")
Problem solved.. The old ones seemed like they had shot seals as they didn't have much hold to them.
Old Oct 21, 2009 | 01:59 AM
maudyZ28's Avatar
Strange, mine are fine seal wise, may leak a bit but still pretty strong. Ill look into it sometime but its not that important
Old Nov 20, 2009 | 02:02 PM
libertyforall1776's Avatar
I have this problem on my '02 RS 3.8L, ANNOYING!!!
Aren't the Hatch Stops and Guides & struts able to be lubricated? What is supposed to be used, and at what spot(s)? White Lithium Grease? Anyone have pics of the exact spots to lube?
TIA!
Old Nov 21, 2009 | 12:48 PM
LHill00Z28's Avatar
I'm not sure, I was too impatient to try to fix & just swapped them out. I think some WLG would work just fine at the base of the rod near the housing.
Try it & report your findings.
Old Nov 22, 2009 | 09:17 AM
cbr600rx7's Avatar
I have a set sitting here at the house if any one out there is looking for a set. They are in good shape i just dont need them.
Old Nov 22, 2009 | 08:31 PM
WLG? What's that?
Old Nov 22, 2009 | 08:42 PM
Used or new? If used, how many years were they on a car?
Old Nov 25, 2009 | 06:16 PM
LHill00Z28's Avatar
WLG= White Lithium Grease
