Harmonic Balancer
Old Oct 4, 2009 | 12:22 PM
jarrod1875's Avatar
Default Harmonic Balancer
I was needing to replace my harmonic balancer on my 2000 Z28 and I was told it would be a good idea to replace it with a performance one. Is that necessary? Which one would you recommend? I have to idea what to get. What's the difference in % under drive? and dampers? If ANYONE could help I would really appreciate it. Thanks!
Old Oct 11, 2009 | 07:58 PM
KPI's Avatar
KPI
Not necessary.
I have ASP. SLP sells ont too. Slp has a key, ASP doesn't.
10% underdrive means you're turning the water pump, power steering, alternator, & AC 10% less than the oem pulley.
If you have a big power-consuming stereo system,you might need an overdrive alternator pulley with an underdrive crank pulley.
LS1 is internally balanced and the crank pulley isn't a damper.
Old Oct 12, 2009 | 12:00 PM
jarrod1875's Avatar
So do you have any recommendations on what I should get?
Thanks
Old Oct 27, 2009 | 07:22 PM
KPI's Avatar
KPI
Sorry for the delayed response. I'd probably get the SLP if I were buying today .I think it comes with an oem crank bolt, but I'd get an ARP crank bolt too.
Old Oct 29, 2009 | 12:45 PM
jarrod1875's Avatar
Thanks. Appreciate all the help.
drifter
Aug 12, 2013 07:00 PM
1976camaro
70-81 V8 Tech
Dec 14, 2010 12:28 AM
camie
67-69 V8 Tech
Mar 16, 2008 12:28 PM
chrshadil
Aug 20, 2007 10:00 PM
chrshadil
Aug 12, 2007 09:03 PM
