1997 Camaro 3.8L to 2000 3.8L swap help needed!!!
Old Sep 29, 2009 | 07:19 PM
siueparent's Avatar
Default 1997 Camaro 3.8L to 2000 3.8L swap help needed!!!
I purchase a 1997 camaro that was missing the complete powertrain. The cut the engine harness on both side to get the powertrain out. I purchased a 2000 3.8l (62K) motor/trans, computer, engine harness and gas pedal. I installed everything but im having a few problems with three connections, the two connection used by the 1997 engine harness for the bcm is ommited in the 2000 3.8L harness and there is a connection the the passenger side that ommited from the 2000 harness. Does the 2000 camaro use a bcm?? Does anyone know what these connection are and if this setup will work. Any help on how to get it running please, tomorrow im going to have the new key made for the new computer. If you click on the pics below you can see the comment i added to the pics. Thanks
Old Sep 30, 2009 | 09:12 AM
what u are doing involves two different style 4th gens. 97 was the last yr of the lts and the 2000 is a ls. i am thinking u will need to change the dash and wiring for it to work. maybe someone with more knowledge on it will come back for ya.
Old Sep 30, 2009 | 10:15 AM
McGnrAcDcfan227's Avatar
Umm, why not sell the 97, and use they money to fix up the '00?
Old Sep 30, 2009 | 11:33 AM
javb_vb's Avatar
The BCM(Body control module) or the EBCM (Electronic Brake control Module)
the 1997 and 2000 have EBCM(electronic brake control module) the 1997 is the one in picture, isn't? I think in the 2000 is in the bcm or in other plase (my english is not really good) but I've the wiring diagram and it say: EBCM(Top of left front frame rail), I've wiring driagrams for the 1997 and 2000 , I've a lot of pictures too, but i don't know how to upload
Old Sep 30, 2009 | 11:36 AM
javb_vb's Avatar
the green and yellow wires, where were they conected? in the 1997
Old Sep 30, 2009 | 01:25 PM
siueparent's Avatar
The connection with the green and yellow wires plug on the steering column, The picture is of the 1997 connector but the 2000 harness uses that extra slot and put a brown wire there. I found out today that the brown wire thats added in ths slot in the 2000 harness goes to the headlights.
Old Sep 30, 2009 | 01:27 PM
siueparent's Avatar
I have the 1997. I brought the powertrain from a guy which is where the 2000 parts come in.
Old Sep 30, 2009 | 01:30 PM
siueparent's Avatar
Is it possible to just get the dash harness out of a 2000 because I dont want to replace the whole body harness because the doors and light wiring should all be the same. Do you think I can splice in the 2000 dash harness at the start of the doors?
Old Sep 30, 2009 | 01:43 PM
siueparent's Avatar
I also changed the brake setup to a 2000 setup.
Old Sep 30, 2009 | 04:52 PM
javb_vb's Avatar
I think it is possible to splice , here are the wiring diagrams the one of the 2000 camaro is with traction control if ur is not I've the camaro 2000 with out traction control to.
File Type: zip
