350 Highoutput Piston/rod/crank/cam ideas?
Old Mar 6, 2005 | 11:48 AM
chevycamarobadass555's Avatar
Default 350 Highoutput Piston/rod/crank/cam ideas?
I've recently bought a few 350 4 bolts and want to go real big with this one...... I need a wide variety of internal parts? I would like to achieve 600 horse with a lil juice
Piston (compression)?
Crank?
Rods?
Heads?
Cam? (lifts and durations)
Intake?
Carb?
Old Mar 15, 2005 | 03:38 PM
70bigblock's Avatar
Default RE: 350 Highoutput Piston/rod/crank/cam ideas?
check out speed-o-motive. They have all hp range motors and what they install to achieve the hp. Their website is http://www.speedomotive.com/ They also list prices you will just need to have the motor prepped and assembled or assemble it your self. I hope this helps you with your motor build. I know it helped me with my motor. Good Luck!
Old May 7, 2005 | 12:16 AM
68RS CRAZY's Avatar
Man wish I would have known about them before I built my stroker. I had a guy at work that told me about this guy that was really good with small blocks . YEA well I found out the hard way. I ordered an eagle stocker kit . and took my heads and intake to him so he could flow them to get a better ideal what size cam to get.my heads are angle milled 60th. so I told him to clay check the heads . He didn't and know I have bent push rods and some bent valves. Good thing I don't own a gun ...
PiN
Mar 21, 2012 11:45 AM
eagans2002
Nov 19, 2008 04:25 PM
350rs
Aug 10, 2008 02:12 AM
Eric89RS
Sep 22, 2007 04:01 PM
Scarface69Camaro
Mar 24, 2007 01:06 AM
