OverHEATING + Airbag + Something like Radiator + Service Engine Soon +Service Vehicle
Old Aug 27, 2009 | 07:50 PM
reaperchild's Avatar
Unhappy OverHEATING + Airbag + Something like Radiator + Service Engine Soon +Service Vehicle
y
Okay 1999 Camaro SS V8 T56 - 6 spd
OVERHEATING : Heat Goes Up & Down Between 210 & Max ..... highwayz will bring it to 215-225 but when idle its stable .... no smoke nothing thank god no leaks ....
Radiater & Coolant tube Are Full (Water)
Fans Are Working 100%
Hyper Tech 160 ... installed but not tuned yet. ....
AIRBAG SENSOR IN THE PICTURE !! ANNOYING !! BLINKS AROUND 6 - 8 TIMES & STAYS STABLE WHILE DRIVING ....
Service engine soon when the scanner tool job was done ..... going back home it comes back again =@
Service Vehicle & the Radiator icon i guess .... no idea but there alwayz on ??
the garage said he is going to check my T56 tranny switch !! or something ......
help ... confused & no idea to solve this headache !!!!!!
Oh BTW y does my trip / oil meter reset everytime i switch on the ignition ???
VIDEO : http://www.youtube.com/watch?v=DgC5OLFVRbM
thnkx
Old Aug 27, 2009 | 10:07 PM
How about some trouble codes. Picture of dash light does not help much in diagnosing things.
Old Aug 28, 2009 | 04:41 AM
nmallory56's Avatar
the one that you put "no idea" is a low coolant level light....learned that one the hard way. (at least thats what it looks like. should be rectangle with arrow pointing down into some waves i believe)
Old Aug 28, 2009 | 05:00 AM
maudyZ28's Avatar
My trim meter used to do the same and no idea why, its fixed now but you dont wanna here how as it was a good byproduct of a very bad thing.
Anyways are the sensors for the coolant pluged in correctly even if it is full, has the car had a bump it would explain the airbag light or the plug may be loose behind the steering wheel or in the dash, dont mes though as they may go off. You need to get the trouble codes really. And also even though it sounds simple have you checked all fuses and relays in the dash and under the hood?
Old Aug 28, 2009 | 10:46 AM
Okay Guyz .... Im Gonna Scan My Car For trouble codes .... & I will Double Check The Fuses Inside & Under The Hood .... Thanx For your replies ??
Old Aug 29, 2009 | 02:30 PM
Overheating .... I refilled the radiator with tap water & for about 1 day it went just fine with no overheating @all where it ran a 200 on the temp gauge ...... today the problem is back =@ .... HELP PEOPLE =S
Old Aug 29, 2009 | 02:49 PM
so is it low on coolant again? did u bleed the air out of the system?
Old Aug 30, 2009 | 07:39 PM
i had a radiator leek , so i changed the radiator but again the temperature when idle is cooler than when driving , when idle the temp gauge is on 215-220 and on hard accelerations temp rises to 250 but nvr saw it go to the max (260) i checked the fans and they are working just fine
my 160 stat is installed but untuned do u think i should tune it first ???
Old Aug 30, 2009 | 08:00 PM
yes either that or take it out and put a 180 in it. that very well could be the problem.
Old Sep 2, 2009 | 12:14 AM
Ill Tune First =/
