Power Door Locks Problem
Old Aug 15, 2009 | 09:47 AM
wolf_t's Avatar
Default Power Door Locks Problem
The power door locks on the driver side do not work. I measured the voltage going to the actuator, there is no voltage when I press lock / unlock.
Is there some kind of relay for this function ? The passenger side works ...
Also, how do I remove the lock where the actuator is attached ?
Thank You !
Car : 2000 Camaro V6
Old Aug 15, 2009 | 03:30 PM
is this a contest? letts seee.... i guess a 97 ss..,, did i win? hay welcome to the forum. what yr is the car? lol
Old Aug 16, 2009 | 09:42 PM
GMDCAMARO's Avatar
I believe the post says a 2000?
Old Aug 16, 2009 | 10:06 PM
ahhh ok... now i feel really supid. lol. 2000 is a bit different than what im used to ill see what i can find. i think he added it.
Old Aug 16, 2009 | 10:40 PM
if u are not getting power to the actuator inside the door then see if u are getting power to the switch on that side. if u have no power to the switch check the wires that come out under the kick pad. now according to the 93 book i have the power goes through the driver side switch from the passenger side so if the passenger side is working then i would suspect the driver side switch.
Old Sep 10, 2009 | 09:31 PM
wolf_t's Avatar
I bought a new lock and actuator. Still does not work .
How can I measure if the voltages to the actuator are correct ? The actuator has two connectors.
So what voltages should be there on which connector if I press lock / unlock on the remote ?
Also, where is the relay for the power door locks located ?
Thanks !
Old Sep 13, 2009 | 07:43 PM
wolf_t's Avatar
So I found out that there is no relay, the door locks are controled by the body control module.
I measure -12 / +12 volt at the driver door lock actuator and 12 volt at the driver door lock switch.
The 12 volt at the driver door lock switch seem to be not right, should be 0 volt (ground), or not ?
Look here (page 39)
http://www.tafmotorsports.com/images...g.diagrams.pdf
Where do I find the body control module (2000 Camaro 3.8) ?
Thanks !
Old Sep 22, 2009 | 08:53 PM
wolf_t's Avatar
No ideas ? Need some help !
Thanks ...
Old Sep 23, 2009 | 08:44 PM
wolf_t's Avatar
Still troubleshooting !
I removed the connector c1 from the bcm and put a wire
between Pin A, Driver Door Unlock (Circuit #694) and
Pin E, Passenger Door Unlock, Pin E (Circuit #1663).
Now both doors lock and unlock !
Without the wire only the passenger side works.
Any explenations ?
Thanks !
[IMG]file:///C:/DOKUME%7E1/wolf/LOKALE%7E1/Temp/moz-screenshot.jpg[/IMG]
Old Sep 24, 2009 | 01:14 AM
have u checked for juice coming to and from the passenger side switch? if u have power to the switch and no power coming out when activated then the switch is bad. if u are not getting power to the switch then u need to look further up the line and find were the juice starts/stops.
silverrocker84
Jul 26, 2011 01:26 PM
80z28guy
70-81 V8 Tech
Jul 19, 2009 03:04 PM
markcamaro
Aug 23, 2008 04:33 PM
streetrace06
Jun 29, 2008 05:03 PM
dnulnarts
Mar 6, 2008 03:51 PM
