Surging and ruff idle
Old Jul 20, 2009 | 12:29 PM
96LT1's Avatar
Default Surging and ruff idle
Hi to all,
I am new to this site and need some help. I have a 96 LT1 with an Lt4 hot cam. I have a problem with the rpms surging at part throttle and the idle is ruff. I have no codes and have done the following. Replaced the iac, tps, map, icm, cts, plugs wires, coil, egr and solenoid and swopped the opti with a known working unit. I have checked the wiring and connections and everything was good. No vacuum leaks and my fuel pressure is at 38 with regulator connected and 45 with out. The regulator is not leaking, and I did drive aroung town with a gauge connected and the pressure stays with in range. Out of all of the things I did the spark plugs helped the most so I thought it had to be the opti. Replaced it and the car ran great for about 50 miles and now it’s worse then before. This motor has 10k miles and was installed in the car about 2 months ago. The computer was programmed by PCM for less. When the engine is acting up it almost feels like you’re hitting bumps. It also has a lack of power. Any help would be great! Thanks in advance.
Old Jul 20, 2009 | 08:45 PM
Have you replaced the plug wires?
Old Jul 20, 2009 | 10:15 PM
96LT1's Avatar
Yes the wires are new from Auto Zone. I went cheap with the wires
Old Jul 20, 2009 | 11:05 PM
what kind of opti did u get? rebuilds are not known for longtivity or quality.
Old Jul 21, 2009 | 06:39 PM
96LT1's Avatar
One from a running L99
Old Jul 21, 2009 | 07:41 PM
my first response would be the used opti bit the big one. i just had a 5 month old msd opti bite it. luckily sumit is taking it back and refunding so im using a gm/acdelco performance this time.
Old Jul 21, 2009 | 08:57 PM
96LT1's Avatar
When yours went did the engine run?
Old Jul 21, 2009 | 09:12 PM
yah but gradually got worse till it idles really bad but touch the gas it dies let it idle it dies. should have the new opti tomorrow or the day after. ill let u know how it goes if u like. only code im getting is 51 prom error. pcmforless says its most likely the opti.
Old Jul 21, 2009 | 09:17 PM
You did not mention the ignition coil module. Before going for another opti, you may want to check it out. It is a lot cheaper than a new opti.
Old Jul 21, 2009 | 09:28 PM
96LT1's Avatar
Thanks, Mine never stalls but it stumbles bad from 1,200-2,000 rpm. The strange thing is I don't see a change in the rpms but I feel it. I tried 2 icm and no change.
