'89 RS, blown head gasket in a 2.8, what to do, or will a 3.4 fit
Old Feb 27, 2005 | 05:07 PM
HotRod53's Avatar
Default '89 RS, blown head gasket in a 2.8, what to do, or will a 3.4 fit
Our '89 RS with 78K on it blew a head gasket. The oil looks like mud and the dipstick is a little blue (but may have always been that way). Do you suggest putting in a new head gasket + it needs valve seals, or I have been told that a 3.4 would bolt right in. Will a 3.4 fit, I guess not just fit, but will it hook up without modification?
Old Feb 27, 2005 | 08:13 PM
3rd Gen Camaro Boy's Avatar
Default RE: '89 RS, blown head gasket in a 2.8, what to do, or will a 3.4 fit
it should fit, but i cant give u a 100% garenty*exuse my spelling*
Old Feb 28, 2005 | 02:07 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
personal opinion, just get another 2.8, its a decent motor for daily driver cars. unless you want to step up and dump a 350 in it, but that requires alot of changes
Old Mar 1, 2005 | 12:26 AM
HotRod53's Avatar
Default RE: '89 RS, blown head gasket in a 2.8..update
I pulled the intake and found globs of foam and sludge. It looks like the rear water jacket gasket is corroded and broken. Now what to do......gasket or swap with a #.4?
Old Mar 1, 2005 | 08:28 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
i dont understand why everyone wants to do that swap. just use the same size motor. i had an 88 Sport Coupe i bought with a blown motor. after getting a junkyard engine and redoing the gaskets and swapping the MFI, the motor ran like a champ...great car probably the best i ever owned
Old Mar 1, 2005 | 08:45 PM
HotRod53's Avatar
Default RE: '89 RS, found a blown intake gasket
After ripping into this thing we found a blown intake gasket. Now, where can I get one without buying a complete rebuild set?
Old Mar 2, 2005 | 02:44 AM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
maybe advance auto or pep boys, shouldnt be that expensive
ChevyRunsDeep93
Apr 28, 2012 10:24 AM
swp5767
Jan 15, 2012 09:17 PM
99 camaro T-Top
Nov 23, 2010 01:24 PM
JoeKramer
82-92 V6 Tech
Mar 22, 2008 12:35 PM
95z
Jun 7, 2006 03:02 AM
