subframe connectors?
Old Mar 16, 2006 | 05:38 PM
mike86rs's Avatar
Default subframe connectors?
I have an 86rs with t- tops no posi yet, should i get subframe connectors? I dont know how much power my motor will make. Im hoping around 400hp. What do you guys think? thanks.
Old Mar 16, 2006 | 07:36 PM
94Z28SHAKER's Avatar
Default RE: subframe connectors?
from your sig, i would say yes, at the least, also think about getting a torque arm, and a heavy duty panhard rod. it will help you plant the rear wheels on takeoff, and also reduce squeeking inside the cabin.
Old Mar 16, 2006 | 08:32 PM
mike86rs's Avatar
ok thanks, I already have the torque arm, what is a good bolt on connector that isn't too expensive,and where would I get them. Thanks for the suggestions.
Old Apr 6, 2006 | 01:58 AM
shnormo's Avatar
Jegs sub frame connectors. I HIGHLY recomend weld in ones, they're a LOT better.
Old Apr 21, 2006 | 07:12 PM
blackz87's Avatar
No matter what power or 3rd Gen car you have the SFC's should be the first Mod you make. I am the original owner of 87 IROC and installed Spohn Tube Type welded in SFC's four years back and my car is still tighter now then when it was brand new.
mindtwister
Oct 10, 2011 12:14 PM
RobsWreck98
Nov 3, 2008 12:13 AM
Bassplayer92
Oct 9, 2008 11:13 AM
nabisco
Aug 25, 2008 07:58 PM
rockin85
Mar 22, 2008 02:19 PM
