HEI vs aftermarket
Old Mar 9, 2008 | 12:51 PM
sgtburks's Avatar
Default HEI vs aftermarket
Not sure if upgrading the HEI ignition will be beneficial to my car the block and tranny are out now and ill be going with a mild set up upon rebuild maybe with 280-300 hp will the HEI be suffucient seeing as the car was only rated at 225 hp stock any help would be greatly appreciated
Old Mar 10, 2008 | 06:22 PM
73camaroSS's Avatar
Default RE: HEI vs aftermarket
oh ya should work just fine,the heishould beable to handle up to like400hp but if your worryed about it you can buy a after market coil at auto zone for cheap, our leave it get good plugs and wires and you should be set, hope i helped you. good luck on the rebuild.
genebrownlow
Jul 28, 2010 08:44 AM
chase0990
Jul 18, 2010 07:58 PM
1968camarosfl
Jun 26, 2009 06:59 AM
MegzZ28
Nov 11, 2007 07:15 PM
CamaroCraz22
Aug 15, 2007 01:29 AM
