New guy on the block from Kentucky, 80 camaro 400hp 350
Old Oct 15, 2004 | 05:18 AM
Rockaholic5002's Avatar
Default New guy on the block from Kentucky, 80 camaro 400hp 350
Just sayin whats up. I finally found an all camaro forum. I have posted a few threads in the classic camaro forum, check them out and please replie.
Old Oct 15, 2004 | 12:10 PM
SStealthBlack's Avatar
Default RE: New guy on the block, 80 camaro 400hp 350
sweet engine. im guessing its not stock. what kind of mods did you do to it
Old Oct 18, 2004 | 12:48 AM
Yeah, its not stock. I got the engine from my dad that bought it from Jim Reed Chevy in Nashville. It started out as a 285 HP crate motor. It has the stock truck 993 heads that are ported and polished, street dominator intake, edelbrock 750 cfm carb, 272 cam from crane retarded 4 degrees, hypertech DUI HEI distributor rotor and coil kit advanced curve kit and shims in the distributor, 10.4 mm wires from Taylor, flat top pistons, headers, exhaust. I've got plans to spray this engine and when it blows, I'm going to build a 355 with a procharger supercharger, able to run 20lbs. of boost. The car also has a th350 with a 2500 stall converter and a shift kit. I've got a set of 3:90 gears from richmond and a pro series posi from auburn to round out the rear end.
Old Oct 18, 2004 | 01:14 PM
sounds awesome. ProCharger is the way to go. My dads got a 1969 Camaro. its a "restofication."
Old Oct 31, 2004 | 02:45 AM
Everyone tells me to go with that new twin turbo kit from Gale Banks power, I'm stuck inbetween doing that and the procharger
Old Nov 1, 2004 | 10:27 PM
go with the pro charger. you'll get more out of it.
Old Nov 8, 2004 | 09:17 PM
That and the procharger is a lot cheaper than the twin turbo kit
snopro_16
67-69 V8 Tech
14
Aug 23, 2022 04:08 PM
tecumseh
Mar 8, 2011 01:01 PM
RSRandy
Jul 22, 2010 03:06 PM
Isphius
Oct 16, 2007 11:11 PM
jdgates11
25
Jul 3, 2007 09:41 AM
