code 15 hard to start while cold runs rough
Old Jan 19, 2008 | 08:32 AM
BEBEAU02's Avatar
Default code 15 hard to start while cold runs rough
I bought 86 IROC plugs were fouled check engine light on hard to start running rough, replaced plugs, wires, cap rotor, coil,and egr valveswapped intake fuel rail sensors off friends car still same problem, replaced coolant temp sensor and adjusted throttle position sensor run better but still hard to start rough idle while cold any ideas what else can cause symptoms
Old Jan 19, 2008 | 01:52 PM
Default RE: code 15 hard to start while cold runs rough
Code 15 is the ECT, engine coolant temp sensor. There are two temp sensors, une for the temp gauge, and one for the ECM. Make sure you changed the one used by the ECM.
Old Jan 19, 2008 | 03:32 PM
BEBEAU02's Avatar
replaced one on front of intake the sensor in block is missing aftermarket temp gauge in hole
Old Jan 19, 2008 | 05:37 PM
BEBEAU02's Avatar
where is the map sensor located found plug on passenger side not attached to a sensor is this the one for map sensor. will no map sensor cause this problem
audioshiver
Jan 20, 2013 09:48 PM
740cordaws
Feb 6, 2012 11:04 PM
Vet76te
Sep 28, 2010 07:37 PM
Racer
Mar 15, 2010 09:25 AM
JRs72RS
Aug 21, 2008 09:05 PM
