Steering Wheel problem!
Old Jan 14, 2008 | 12:36 AM
1979RS's Avatar
Default Steering Wheel problem!
Hello any one who reads this
I got a 1979 RS duh this car is new to me so i'm not sure of all the changes the previous owner made, well my problem is that when i'm driving my sering wheel feels lose and sometimes it tends to go to the right, i thought it could be the alignmet but i'm not too sure, the steering wheel was also changed from the original so I want to know why is that it feels so lose and gives me this problem. Can someone help me? PLZ
Old Jan 14, 2008 | 12:39 AM
1980rscamaro619's Avatar
Default RE: Steering Wheel problem!
Its prolly that its not a stock steering wheel and they didnt put it on right how is it loose? like the play on the wheel or back and forth? Just took out my steering wheel in my 80 maybe they didnt put in the horn part which would also make it loose, does the horn work? [align=right]
[/align]
Old Jan 14, 2008 | 03:51 PM
If your steering wheel can rock back and forth on the steering column, that's one thing. But it sounds more like you have slop in the front suspension. There's also a good chance there's slop in your steering box. Since you feel looseness in the wheel, and the car wanders on you, I would suspect things up front such as your tie rod ends, drag link, etc. are probably shot. Get someone inside the car to rock the wheel left and right, and look under the car and under the hood to see what's moving before the wheels start to turn. Have it looked at before the car decides to take a sudden turn on it's own.
Old Jan 14, 2008 | 09:43 PM
1979RS's Avatar
Aright thanx to both of you!
Yeah the problem with the steering is at the play like 1980rscamaro619said, it is at teh time of making a turn, the steering arm doesn't shake is just atthe time of making a turn that it feel lose.
well about the horn it doesn't work.
Thanks again and i will do what you said Camaro 69i'll look more closely at it. nice ride by the way.
Old Feb 20, 2008 | 07:45 AM
HOTROD MOMMA's Avatar
IM KINDA HAVING SAME PROBLEM I HATE IT,BUT I JUST STARTED TARING INTO THE FRONT END AND REPLACING TIE RODS BUSHING LINK PINS,NOT SURE IF ITS DRIVING BETTER BUT I WILL LET YOU NOW LATER JUST GOT IT ALL PUT BACK TOGETHER LAST NIGHT : )
bbar
Mar 29, 2011 11:00 AM
94.V6.VROOM
Jun 30, 2009 01:01 PM
1979RS
Jan 15, 2008 09:37 PM
Conundrum
Jul 6, 2007 11:48 AM
