positive traction
Old Oct 30, 2007 | 01:52 PM
chucks71maro's Avatar
Default positive traction
what is the easiest and cheapest way to get positive traction?
Old Nov 1, 2007 | 08:20 PM
realitygt's Avatar
Default RE: positive traction
weld your spider gears together
Old Nov 15, 2007 | 10:14 PM
78 LTRS camaro's Avatar
or you could just get some traction bars there pretty cheap and do a good job at getting the weight transferred back there
Old Nov 17, 2007 | 03:28 AM
670eddie's Avatar
realitygt
titleAndStar(25,0,0,false,",")
Starting Member
[align=center][/align]
Score: 0
Status: offline
Seriously??
Old Nov 17, 2007 | 08:24 AM
RcrX's Avatar
welding the spder gears? that basically a spool isn't it. that won't do any good if u drive it on the street.
Old Nov 17, 2007 | 10:40 AM
daltons 1980's Avatar
if you weld the gears it chirps when you turn..thats all my dads el camino did when he wlded them
Old Nov 17, 2007 | 05:25 PM
RcrX's Avatar
yea, and it'll make it a little harder to steer. i having the same problem, i'm on limited budget and i wanna get a posi bc i have an open diff. i can get a descent posi unit out of a sec gen for around a hundred bucks, but don't kno how to set it up w/ shims.
Old Nov 17, 2007 | 05:41 PM
ORIGINAL: 78 LTRS camaro
Traction bars keep the rear axle from twisting under torque (rising at the pinion point)which prevents the leaf springs from doing a wrap n' snap!It has nothing to do with comparing the traction capabilities ofa positraction versus an open diff axle. The easiest way would be to have someone else set it up for you, but that wouldn't be the cheapest. The other easiest, and possibly cheapest way would be to find a goodused drum to drumposi unit, but original ones aren'texactly a dime-a-dozen.Another option is to go with a Ferd 9", which is what I have under my 69. I have seen used ones for sale on Ebay in the past, you might want to do a search and see what you find. And, welding the spiders is ok, as long as you only drive in astraight line!
dchatcher
Apr 28, 2009 01:44 PM
bidicamaro
May 1, 2008 05:01 PM
jpepper
Apr 23, 2008 10:36 PM
bowtieguy
Dec 15, 2006 02:22 AM
