Cleaning in the engine compartment
Old Oct 22, 2007 | 12:43 PM
sante65's Avatar
Default Cleaning in the engine compartment
Any suggestions on how to best clean all the grime and undercoating in my engine compartment? I have removed the engine and I want to clean everything before I put the engine back in.
Old Nov 7, 2007 | 10:44 PM
nscfn8's Avatar
Default RE: Cleaning in the engine compartment
idk about what to use with the engine out...but for a quick job before a show or something i like to use simple green...and dont dilute it...it gets the dirt and grime right up and works fairly well considering the short amount of time i usually have...it worked awesome when i bought the car and the intake and covers had crap all over them...
Old Nov 7, 2007 | 11:42 PM
The Banks's Avatar
ORIGINAL: nscfn8
Do you just spray the Simple Green in the engine compartment, and then rinse it away, or do you actually have to wipe/scrub it then rinse?
Old Nov 9, 2007 | 06:51 PM
The Banks's Avatar
Well I picked up some Simple Green Max today and hopefully will be able to try it out in the engine compartment this weekend if it doesn't rain.
Old Nov 10, 2007 | 10:22 AM
nscfn8's Avatar
i wipe it off just in case it doesnt pick all of it up...lemme kno how it works out for you..
Old Nov 10, 2007 | 12:59 PM
The Banks's Avatar
It works great. I used the Simple Green Max and an older microfiber towel I previously washed. It looks and smells clean . My only problem are those hard to reach tight spots. Maybe I'll spray some Simple Green in those places, run a little water, then blow it out with the compressor.
Old Nov 12, 2007 | 12:46 AM
tonkabully's Avatar
hi, i have used varsol/paint thinnerfor real grimmy areas the grease and grime practically run off by itself.only ever tried it in the engine bay area.
Old Nov 12, 2007 | 07:48 AM
bluovlh8er's Avatar
im going out to wash mine right now lol, ill let you know how it turned out...
Old Nov 12, 2007 | 06:30 PM
Chappie99's Avatar
Um...I have a great idea. No engine in engine bay.. Wrap plastic bags around all your wire harness, get yourself a average pressure washer. Buy some engine brite, soak the engine bay and spray the **** out of it with high pressure water. BAMMMM... clean engine bay.
Old Nov 13, 2007 | 01:01 PM
bluovlh8er's Avatar
thanks bay...
