Adjusting 3rd Gen IAC & TPS
Old Oct 6, 2007 | 04:38 PM
Default Adjusting 3rd Gen IAC & TPS
IAC and TPS Adjustment
Tom KeliherMar 31 2006 - 3:07pm
Idle Air Control
Tools needed:
[ol][*]Torx bit # T-20[*]Paper Clip[*]Small Punch
[/ol]
Take the paper clip and open it up and form it into a big "U" shape. Insert the clip ends into the ALDL in the 'A' and 'B' pins.
Turn on the ignition, but don't start the engine. Wait 30 seconds. Now, go remove the connector from the IAC.
Start engine. You are now going to adjust "minimum air". There is a Torx screw on the side of the throttle body. This is what needs to be turned to adjust minimum air, or more commonly known as "idle speed". It comes from the factory with a protective metal cap over it. If the cap is still there, use a small punch to knock it out. Set the idle speed to 450 rpm, rotating the Torx screw clockwise to raise rpm, and counter-clockwise to lower rpm. Once the idle rpm is set, turn off the engine.
Re-connect the connector onto the IAC. Start engine. Idle speed is now once again governed by the ECM, but your idle should be smooth and steady, approximately 600 rpm in Drive (for unmodified cars).
If you set an SES light by having the IAC disconnected, then after shutting down the engine disconnect the negative battery terminal. Wait 5 minutes. This will clear the ECM of all trouble codes. Re-connect the battery and drive the car for 20 minutes to allow the ECM to relearn your driving style.
Throttle Position Switch (TPS)
Tools needed:
[ol][*]Digital Volt-Ohm-Meter (VOM)[*]Jumper Wires (make your own)[*]Auto Xray Scanner (if available) will eliminate the need for VOM and jumper wires.
[/ol]
Turn on ignition, but don't start the engine.
With a scanner: plug in the scanner and read the TPS voltage. It should be 0.54Volts +/- 0.075Volts
With VOM and jumper wires: disconnect the connector from the TPS. Using your jumper wires, make a connection allowing some room for the VOM terminals to contact the jumper leads and read the TPS voltage.
If out of spec, loosen the two screws holding the TPS to the throttle body, and slightly rotate the TPS up or down, reading the voltage until it comes into specification. Tighten screws. Using the throttle lever, rotate the throttle to WOT (wide open throttle). The TPS voltage should be over 4.0 volts. Close the throttle again, and then slowly open it to WOT, observing the voltage reading. It should increase progressively and in a linear fashion. If it sticks or jumps or falls off at all while doing this check, that could mean a bad TPS switch and could be a cause of stumbling and driveability problems.
After setting the correct voltage, turn off ignition switch. Remove jumpers/scanner and reconnect the TPS connector as required.
Old Aug 2, 2009 | 10:43 AM
CNCman's Avatar
Hey Z28 Pete ! i have a 1994 Z28 LT1 , will this work on it also ?
I just ordered a Autoxray 5000 from Ebay for 163.00. Soon i want to get
something to program with, but not sure yet what to buy, ihave a good laptop
with winXp. Got any suggestions ?? Thanks !
ragtag
Nov 2, 2013 07:23 AM
AmericanMuscle1989
Jun 16, 2013 03:32 PM
sante65
Aug 15, 2009 10:42 PM
HotRod53
Mar 8, 2005 11:35 PM
