Saving Gas?
Old Nov 22, 2005 | 11:21 PM
bootwagner's Avatar
Default Saving Gas?
Hey does anyone have tips on saving gas on an LT1 camaro. now i get 14/23 and was hoping for at least 16/24. Do headers help?
Old Nov 23, 2005 | 12:28 AM
Boost's Avatar
Default RE: Saving Gas?
regular maintence like Air Filter, Clean your Spark Plugs, change oil, Make sure your tires are at max pressure
Old Nov 23, 2005 | 03:43 AM
Hisss04Cobra's Avatar
Stop putting your foot to the floor when you leave a red light!!!
Old Nov 23, 2005 | 10:12 AM
Lee Willis's Avatar
Long tube headers that tend to be small in diameter will
generally around town fuel economy by about 1 mpg
(if you have a stock cam, no telling what will happen
if you have an aftermarket cam).
Putting in more air pressure in the tires, up to the max
that is reasonable for the tires/car, will do the most. I
had an Audi S4 recently (4.2 liter 340 Hpo V8) that
gained 1.5 mpg going from 28 to 32 lbs air pressure.
If you have a manual trans, shift at 1500-1800 RPM. The engine
has the torque and running at below 2kRPM will save gas.
Old Nov 25, 2005 | 09:34 PM
RatedZ's Avatar
Make sure your plugs/wires are up to snuff, your fuel filter is in good running shape, your tires have the recommended amount of air in them, your air filter is clean, your fuel injectors are running up to snuff, and stay out of the throttle.
Old Nov 25, 2005 | 11:31 PM
Don't drive it, till u really need it to stomp on a Mustang or some ricer.
U got a pretty big V8 and moving all that metal around uses gas. Keep the car in good tune, light on the gas pedal, coast whenever possible. short shift if u have a manual trans.
Old Nov 26, 2005 | 01:39 AM
RatedZ's Avatar
ORIGINAL: z28pete
Nah, don't even waste gas on some lame ricer. It's more of an insult NOT to race him.
Old Feb 25, 2006 | 12:17 AM
jus_business932's Avatar
according to www.fueleconomy.gov the average for a V8 5.0 is 17/25...
and some guy on this forum told me he gets 25mpg on his 89 ls v8 if i can get 25mpg on a third gen camaro i would buy one right now.
MaVeN
Apr 4, 2011 03:37 PM
86sbZ28
Jan 21, 2011 09:24 PM
67vertChuck
Feb 3, 2008 06:06 AM
ravenforbidden
70-81 V8 Tech
Dec 6, 2007 09:07 AM
chrshadil
Aug 10, 2007 06:00 PM
