horn!!!
Old Jul 10, 2007 | 10:25 PM
Rs Camaro Kid's Avatar
Default horn!!!
My horn in my 3.1 doesnt work....where are the connections for the horn? ive already checked the fuse
Old Jul 11, 2007 | 01:32 AM
MadMikeZ28's Avatar
Default RE: horn!!!
When you push the button can you hear a relay click? What year is it? Is it an air bag wheel? The air bag shrinks and makes it hard to push the buttons for the horn.
Old Jul 11, 2007 | 04:00 PM
zeus8807's Avatar
Default RE: horn!!!
easiest way to test if its the horn itself, if get yourself a nice 12volt battery any size will work, and hook it to the horn itself with a little wire, if it goes off its your button or your wiring, both easy fixes(unless u have the air bag its a little more of a pain in the butt.
Old Jul 11, 2007 | 08:29 PM
Default RE: horn!!!
its a 91...i believe it has a airbag wheel,and ill have to see if i can hear the relay
Old Jul 11, 2007 | 09:47 PM
MadMikeZ28's Avatar
Default RE: horn!!!
There are square buttons on both sides of the wheel and the air bag has a plastic frame behind the vinyl with a hole that the switch goes through. The vinyl has raised areas in it that go through the hole to make contact with the buttons. After ageing the vinyl will shrink and the raised areas no longer fit good in the holes in the frame and make it hard for it to contact the buttons on the wheel. At least that is what happened in both my 91 and my brothers 90 Camaros. Is your air bag kinda pulled away from the wheel a little bit where the horn buttons are?
Old Jul 12, 2007 | 09:22 PM
Default RE: horn!!!
ya thats how my wheel is...it looks like the covers comin off kinda
Old Jul 13, 2007 | 01:26 AM
Default RE: horn!!!
how can i fix that??
Old Jul 13, 2007 | 03:36 PM
MadMikeZ28's Avatar
Default RE: horn!!!
I tried to fix mine and my brothers. I had the bag off and tried to pull the cover back over the framing inside and its just shrunk up. Maybe the hole where the pad goes through can be enlarged or the vinyl can be cut to fit through it. I dunna know. I just gave up because I usualy yell or show a finger any way.
PCweber
Apr 27, 2012 12:55 PM
ampprc
Nov 4, 2010 02:12 PM
brunk5
Oct 22, 2010 11:54 PM
kevink713
May 10, 2008 09:03 AM
hsdragracer
Mar 30, 2007 11:26 AM
