AC blows out of Defroster??
Old May 7, 2007 | 04:43 PM
awdrifter's Avatar
Default AC blows out of Defroster??
My AC will only blow out of the defroster vents. It doesn't matter what you turn the *** too I don;t really car about it not changing but I want it to blow out the AC vents can anyone help identify which vacuum lines to change or point me to a thread that can thanks George
Old May 7, 2007 | 05:59 PM
MadMikeZ28's Avatar
Default RE: AC blows out of Defroster??
You most likely have a problem with you vaccum source. When there is no vacuum to the blend air doors defrost is the default position. Check the hose coming off the intake manifold and there should be a ball located inside the ront of the left fender under the head light area. that is a resivour for vacuum.
kaoticjester
Jan 9, 2012 08:34 AM
cncfe
Jun 8, 2011 08:01 AM
feltennova
Aug 7, 2010 09:29 AM
azmattaz06
Aug 4, 2009 03:03 AM
4thgenridin
Apr 27, 2009 10:10 AM
