dripping gas
Old Apr 16, 2007 | 08:58 PM
countryboy's Avatar
Default dripping gas
My gas tank leaks alittle only when i go from like warm to cold wheather. Like when i park my car in the garage on cold concreat after being outside in the warm weather. I think it usually runs down the side of the tank. I figured it was prolly coming out off the vent on top. When i open the gas cap there is usally alot of pressure built up and that usually fixes it. It dosent like always leak tho so its not a leak in the tank or nothin i dont think. Would a gas cap do that? Any other ideas would be great. Its not a big problem but somthing that would be nice to fix.
Old Apr 18, 2007 | 08:30 PM
countryboy's Avatar
Default RE: dripping gas
I went out to the garage today again and there is gas on the floor thats dripping form the tank. I know it has to be somthing with the cap or somthing cause if i loosen the cap up it dosnt leak. I think i'll try a new cap then since the old one dosent seem to be letting out the pressure. If this sounds like it could be the problem please let me know. Thanks
Old Apr 18, 2007 | 10:45 PM
nzink's Avatar
yep, thats what it sounds like to me. When its warm out or you drive around, you're creating pressure in the tank, you probably don't have a vented gas cap. Get one and i bet that will fix it.
Old Apr 18, 2007 | 11:23 PM
Emission regs require he cap in your car is to hold the pressure and not vent fumes out. If working properly the cap will only allows air in as the fuel is used up. Because it is holding pressure, it forces the gas to come out where the leak is. Probably a pin hole in the tank or fuel line.
Old Apr 20, 2007 | 11:18 PM
countryboy's Avatar
I got a new cap and it seems to have fixed it.
Old Apr 23, 2007 | 12:50 AM
bluovlh8er's Avatar
lucky
jessedgraham
Nov 30, 2011 01:38 PM
jeepsrock
Aug 15, 2011 12:02 AM
BoricuaHec01
Mar 15, 2011 08:34 AM
BLK_CZ28
Oct 13, 2009 11:39 PM
Thoreau
Aug 14, 2009 02:45 PM
