Stock gears and rear end
Old Apr 9, 2007 | 10:53 AM
SteveO87's Avatar
Default Stock gears and rear end
I was just wondering what the stock gears are in a 94 z28? and is the stock rear end strong enough to handle a supercharger or do you have to change the rear end?
Old Apr 9, 2007 | 05:11 PM
Default RE: Stock gears and rear end
There were 3 different gear ratios available in 94: 2.73, 3.23, 3.42. The 2.73 was standard equipment on auto transmissions, 3.23 was the performance option on auto transmissions, 3.42 was for manual transmissions. The stock rear will probably stand up under a supercharger as long as you don't use slicks, but without them the supercharger won't do much good.
Old Apr 9, 2007 | 08:07 PM
LT1RUNNER's Avatar
Is there an ID# on the axel to tell what gears you have?
Old Apr 9, 2007 | 11:09 PM
SteveO87's Avatar
Not sure...but im goign to call a dealership with the VIN # to find out what it was sold with...hopfully they can tell me...so...the highest gears i can put in the car are 3.42...how come i have seen cars with 4.10 the same year as mine..does that mean they have already changed the rear end totally?
Old Apr 10, 2007 | 12:28 AM
The factory only put those gears in, but you are free to put in whatever gear ratio you can get to fit. Aftermarket, salvage yard,or GM.
Old Apr 10, 2007 | 09:15 AM
SteveO87's Avatar
well that is good news...i was hoping that i was able to do so...thanks pete
heartbeat_jr
70-81 V8 Tech
17
Mar 14, 2021 05:56 PM
greycon88
16
Jan 19, 2012 06:28 AM
vteckiller
Dec 3, 2009 01:53 AM
fatass91
Jun 30, 2006 06:41 PM
99CamaroOwnr
Oct 1, 2005 09:58 PM
