Skipshift? what the hell is this.....?
Old Apr 4, 2007 | 08:01 PM
fastfive_ogt's Avatar
Default Skipshift? what the hell is this.....?
I just purchased a 95 z28 6spd. and it has this stupid skip shift. Is there anything I can do to eliminate it?
Old Apr 4, 2007 | 09:59 PM
Default RE: Skipshift? what the hell is this.....?
Get a CAGS eliminator from Jecs or Summit.
Old Apr 4, 2007 | 10:11 PM
coprunr's Avatar
doesn't somone on here know to make your own skift shift eliminator z28pete? i thought i saw it in a tread right after i joined.
Old Apr 4, 2007 | 11:28 PM
Skip shift eliminator?
Old Apr 4, 2007 | 11:33 PM
ORIGINAL: coprunr
For what these things cost, I don't think it is worth going through the trouble of building one. But here is how.
http://www.f-body.org/faq/4/4_3.htm#ch4_3d
Old Apr 24, 2007 | 09:55 PM
mcnair's Avatar
I'm not sure if this is a coincidence or the rule. When I first got my z28 the skip shift never came on. Then I had a new clutch put in and the mech asked me if I wanted the wires at the back of the trans connected and I said yes. Then I found out what a skip shift was. The wires are still there but I just hit it over 2000rpm and then can shift. No Biggy
Old Apr 25, 2007 | 07:58 PM
musclecarguy's Avatar
what does the skip shift do?
Old Apr 25, 2007 | 11:30 PM
Prevents you from shifting into 2nd or 3rd and go directly to 4th, unless you rev 1st gear high enough. Supposed to save gas, but just a PITA otherwise.
Brayan99
Nov 4, 2011 09:55 PM
BlueKitsune
Feb 26, 2009 11:58 AM
th3po1son
Dec 18, 2007 06:48 PM
