88 305 tpi service engine light
Old Aug 6, 2005 | 01:42 AM
eric302's Avatar
Default 88 305 tpi service engine light
Hi, My daughters 88 IROC 305 tpi 106k mi. service engine light has been coming on. I flashed the computer and got three and then four flashes. The decoding in the Haynes manuel doesn't seem right. I replaced the o2 sensor but didn't make a difference. Also the idle seems erratic at times but I can't seem to find any vacuum leaks. Any ideas? Thanks!
Old Aug 7, 2005 | 01:22 PM
eric302's Avatar
Default RE: 88 305 tpi service engine light
I think I found my problem, possibly the MAF. I found the codes here. http://www.fbodymotorsports.com
Old Aug 10, 2005 | 12:21 AM
aaronsirocz's Avatar
IF THATS NOT IT TRY THE IDLE CONTROL CENSOR, THAT WAS A PROB. WITH MINE. IF ITS BAD UR CAR WILL NOT IDLE RIGHT, ALSO IF IT IS MOVED UP OR DOWN IT WILL MAKE IT IDLE DIFFERENT TOO. AARON
Old Aug 19, 2005 | 10:58 PM
eric302's Avatar
Hey thanks Aaron, I cleaned the MAF and after resetting the ECM the light has been off for the past week. Hopefully this will help someone else.
Rent
Apr 22, 2013 11:08 PM
m-samuels@sbcglobal.net
Sep 21, 2011 08:07 PM
bchbmjohn9
Sep 5, 2010 11:44 PM
93CamaroGirl
Apr 27, 2007 01:15 AM
red99camaro
Apr 12, 2007 12:04 AM
