plugs
Old Aug 5, 2005 | 02:47 AM
deang423's Avatar
Default plugs
what's the easiest way to change plugs? What do you take off to get to them? Also, what is the best plug to use?
thanks
Old Aug 13, 2005 | 09:11 PM
Default RE: plugs
Depends on the car, but if it has a LT1 motor, you can do the driver side from under the car, the right side it helps if you drop the headpipe and work from underneath. While you are under there change the plug wires also & make sure to put back the aluminum heath shields on the plug end of the wire. I also suggest you replace them with the factory plugs, they are expensive but last for 100K. You really don't want to change plugs in this car unless you really have to.
hoursetraitor
Apr 25, 2011 10:14 PM
distefanos
Jun 21, 2010 11:58 AM
CraZ28
Feb 14, 2010 10:15 PM
purpl96
Nov 26, 2007 05:52 PM
84 z .....
Sep 25, 2007 11:25 PM
