backup lights wont work??
Old Nov 18, 2009 | 11:04 PM
ROWDYROB's Avatar
i looked at every wire under there--only switch type item i seen was for the brake?--got me stumped--i dont even know how it could send power to those lights,because i cant find anything on the tranny or shifter --so how could it turn them on when put in reverse???--thanks
Old Nov 19, 2009 | 04:17 AM
what yr is your car? is there a shaft or bar that runs from the trans to the steering column?
Old Nov 19, 2009 | 09:39 AM
ROWDYROB's Avatar
ITS a 77 and it has a hurst shifter in the floor with just a cable going to the tansmission linkage--and i cant see any wires or switches that would trigger the backup lights??--seems too simple to be causing this much of a headach!!
Old Nov 19, 2009 | 06:02 PM
  #14
Look under the hood at the steering column. It may be that the Hurst shifter was installed and the linkage to the column was not hooked up. You should see an arm near the firewall on the column that has either linkage hooked to it, or a hole for linkage. If that arm is not hooked up it wont activate reverse lights.
Old Nov 19, 2009 | 07:27 PM
  #15
^^^ yep thats what im thinkin. should be able to get a switch for the aftermarket shifer if its gone.
Old Nov 20, 2009 | 12:06 AM
  #16
ROWDYROB's Avatar
yep--i was just getting ready to post that i had found out that the rod from the linkage to the column was missing---anyone know were i can get one?--or would the switch be better?--and were i would find one of those---i think i would be fine with just the origional rod--as can pull down some on the column link and the lights will come on ----thanks
Old Nov 20, 2009 | 04:36 PM
  #17
If the rod is gone, it probably wouldn't mate to the new shifter anyway. I'd contact Hurst and see what they have for an accessory switch and wire one in.
You still need to find that switch on the column, but once you do you can just splice the two wires to the new switch and you're good to go.
pojo1988
Aug 27, 2017 09:35 PM
karma187357
Feb 23, 2013 10:37 AM
tbl76camaro
Apr 25, 2011 01:06 AM
Gorn
Jun 4, 2010 11:00 AM
tyler2497
Jun 15, 2007 10:31 PM
